Over honed cylender
jmann
have a 1999 150 evinrude i thi
have a 1999 150 evinrude i think i over honed one cylender was wondering if anyone new how much over i could get away with thanks for the help
"that needs to be measured for
"that needs to be measured for tolerance,a hone should only be used for a few seconds at a time
with a good quality lube,back to the question
need to know origanal size/size after the ooopps"
"The bore should be honed usin
"The bore should be honed using kero so the hone stones can work and the cross hatch pattern should be at 60degs... Get a new ring and place the same ring in each bore down about an inch and measure the ring gap...in the service manual it will give you the min and max ring gap, then you will know if you have over honed or not"
