65 hp johnson more problems
daniel
Joe we have spoken earlier ab
Joe we have spoken earlier about a 65 hp johnson 1972 with shift problems. I had found low voltage to the reverse soleniods. I also found on the port and starboard side of the power head a melted plastic. It seems to have come from just under the flywheel. It is a coil looking device. there are 2 that I can see that have melted. what are these and any ideas what to do? Thanks
Daniel
I found out this is the stato
I found out this is the stator...Anyideas where to find one and a regulator/rectifier?
"Daniel.... The stator on that
"Daniel.... The stator on that model is the beginning of the ignition system and also the charging system. I do have a new one left in stock, also a rectifier. I'll contact you with their respective prices.
Joe
