"Hi, new to this forum. Read a
"Hi, new to this forum. Read a lot and used some of the info here.
I now am in need of help. I just had my 1986 OMC 1.6L Seadrive overhauled. The mechanic put a Johnson 115 or 140 powerhead on with the bubbleback. First 10 breakin hours she ran great...of course the normal spitting/dying due to double mix.
So,just changed the plugs...put in the QL77JC4 and gapped a .40.
Also, my tach was not working properly and from reading others posts here, I replace the regulator/rectifier. Seems tach is now working ok.
Took it out today, would not plane. Started and idles ok, but when opening it up and trying to plane out, it goes up to approx. 2800 rpm's and that is best it will do. Seems to have take off power, but limits at this RPM.
First question: The new regulator/rectifier was different only in that the red wire that goes to the starter solenoid was only about 14 guage. My original one was much heavier gauge...maybe 8 or 10 guage. Is this a problem?
Second question: I pulled each plug, grounded against the engine and fired it up. They all fired strong except for the top left one. In the sunlight, it was hard to see any spark. The plug was not even wet. Is it possible I have a bad coil? Or is it possible the new regulator/rectifier is the problem in that the red wire does not carry enough load? Not sure what the red wire is supposed to do."
