Click for Volvo Penta manuals!
Results 1 to 3 of 3
  1. #1
    Ola's Avatar
    Ola Guest
    Default "Anyone who has experience of
    "Anyone who has experience of loosing coolant in a TAMD 41 or AD 41? There is no leakage outside the engine, no water in oil or oil in cooling water. I have replaced the gasket between the manifold and turbo, with no effect. Now I need suggestions to go further."
  2. #2
    Join Date
    Sep 2001
    Posts
    434
    Default "IT MUST BE BLOWING OUT THE EX
    "IT MUST BE BLOWING OUT THE EXHAUST, MIT BE A CRACKED MANIFOLD"
  3. #3
    Join Date
    Apr 2007
    Location
    Norway
    Posts
    9
    Default "Hello Its 1 the turbo gaske
    "Hello
    Its 1 the turbo gasket where the turbo is attached to manifold. The old type is no good. The new type is 2 mm upon the flange of turbo. Its a steel type.Check if you have new type gasket and replace if not.
    2. The cyl head gasket. Last update is 1999,but can leak anyway. One replacement and its ok. My theory is too bad tightening at factory as one replacement fix the problem even is engine had latest version gasket. (for example KAD43)
    Pls note all leaks can bee seen as brown tracers on block below exhaust manifold and under flange turbo/manifold.
    Regards Ingvar
    (3 cylhead gasket replacement so far this year)"
Similar Threads
  1. Loosing coolant
    By Don Brown in forum Yanmar
    Last Post: 06-25-2015, 06:08 AM
  2. loosing coolant from heat exchanger 1988 aq 131 d
    By tom1234 in forum Volvo Penta Gas Engine Forum
    Last Post: 05-25-2010, 04:56 PM
  3. volvo 131d loosing coolant from heat exchanger
    By tom1234 in forum Test posting of messages, photos and formatting
    Last Post: 05-25-2010, 11:49 AM
  4. Loosing coolant on 454 fwc
    By denis_k in forum Crusader Marine Archive
    Last Post: 06-24-2009, 06:08 PM
  5. Tamd 41 coolant question
    By 80tiara in forum Volvo Penta Diesel Archive 2004-2009
    Last Post: 09-05-2008, 09:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
