mrwoodboat
"ok got the 440 torn down, hea
"ok got the 440 torn down, headgaskets look intact,so how does one go about pressure testing the manifolds? I am assuming I could make a plate to replace the outlet and then put a schrader valve in one of the drain plugs and use a hand pump to put some pressure in the manifold...how do I tell if it is the manifold or the riser? I would like to verify this before I put the new gaskets and all back together. Any help here is appreciated. Thanks"
