"Hello,
After all the help
"Hello,
After all the help from this forum, I have my twin engines running well. The only problem, which may not even be a problem but instead just the nature of outboards is the following. When going down the canal at slow speed (5 knots 1000-1200 rpm) the engines (one a little more than the other) vibrate, and put out a quite a bit of blue smoke. I thought it may be the slow speed idle adjustment on the carbs that may be out of tune. Reading the manual didn't provide much insight other than the initial setting is 3 turns out from slightly seated.
My question is how, do I go about adjusting the carburetors on my twin 1995 Evinrude 175's which are optical V6 60 degree engines.
Thanks again,
Andrew"
After all the help
"Hello,
Thanks again,
Andrew"
