M
Mike T
Guest
"I have an 86 Four Winns and w
"I have an 86 Four Winns and was wondering if I should go with a closed cooling system (have one in a box). Boat came with a sea pump, and also has a pump in the outdrive. Will the outdrive pump be sufficiant? Or should I use the front sea pump since it's there. Its a 27ft w/260 and uses a jack shaft. Also, boat is in Florida and sees salt water every weekend."
