"My 1995 Mariner 225HP with 1,
"My 1995 Mariner 225HP with 1,000 hours started running hot. I change the water pump, poppet valve, thermo's and flush religiously. So I pulled the heads. The water passages were perfect. I noticed four of the six piston heads had dime size shinny spots on the outer edges. The cylinder O ring seals didn't look that bad, however I believe water was bypassing in. I'm replacing all the gaskets and O rings. Would this cause the engine to run hot? Also, what's the best way to remove the carbon film on top of the pistons or should I leave it alone? Thanks..."
