daytona_sportfour
"I purchased an Boat/engine on
"I purchased an Boat/engine on eBay a couple months ago- and am happy to report I got a good deal. However, the engine was not "original" to the boat. I got the controls and wiring, but not the "dash". I have a 1964 Wiring diagram (that is supposed to be the same)But there are a couple differences. See the photo below:
dashwiring"">
1) What is the White w/red stripe wire for? It goes into the control box to the 6-pin connector, but I lose it after that. What should it connect to at the "dash"?
2)What is the Red w/White stripe wire for? I assume it is for the electric shift, but that wire is not included in the '64 diagram (only the green and blue). It traces to the 3-pin connector in the main control box, where it joins the Blue and Green (Forward-Reverse) wires for the shift. Does this wire connect to the IGN terminal on the Ignition Switch?
I am going to build my own custom dash panel to mount the Ammeter, Tachometer, Ign Switch, and warning lights.
Thanks,
Ray"
Thanks,
Ray"
