Tacho connection
H
Hendry
Guest
"I have a 73 Evinrude 85hp and
"I have a 73 Evinrude 85hp and bought a set of gauges which included a tacho with systems check (No Oil, Hot, Chk Eng, Low Oil). The tacho has an eight point plug connection at the rear. As this model does not cater for the systems check, I would still like to connect the tacho. The plug is only available with the wiring harness. Would anyone be able to help in identifying the pins so that I can connect the tacho wire, or explain how I can identify this?
Thanks for the help
Hendry"
