Results 1 to 4 of 4
  1. #1
    Join Date
    May 2006
    Location
    Pass Christian, Mississippi, USA
    Posts
    5
    Default "I have recently purchased a b
    "I have recently purchased a boat with a 70 HP Mercury, Ser No. OB373913. I am guessing a 90 or 91 year. Can someone identify?"
  2. #2
    Join Date
    Nov 2005
    Location
    , il,
    Posts
    2,198
    Default "[url=""]http://www.themarined
    "http://www.themarinedoctor.com/cgi-bin/YaBB.pl?board=MM;action=display;num=1137539327
    88 3cyl if you drop the first digit of your #"
  3. #3
    Rick Golden's Avatar
    Rick Golden Guest
    Default "I have a 1989 70 HP mercury O
    "I have a 1989 70 HP mercury OB motor that I finally got running well. Now I am having a problem with the tilt going up & down. Does anyone out there know where the manual release would be, if there is one? The manual I have says there is one, but I can not locate it.
    Thanks in advance."
  4. #4
    Default Re: Mercury 70 HP Year
    I have a 1989 Mercury 70 HP and it died and wouldn't turn over. I knew what that meant but didn't want to believe it. Yes it seized..I tore into it to rebuild it and the number 3 cylinder has some grey color in it and is dry and the plug has the same. The other 2 cylinders are good. I know this is a common problem but what made it grey? Misfire? Not cooling properly? Contaminated fuel? As you see I been doing a lot of reading. Has anyone ever seen this? What can I do to prevent it happening again?
Similar Threads
  1. Mercury 98 year
    By kman077 in forum Mercury Mariner Outboard Archive
    Last Post: 07-24-2007, 01:32 PM
  2. Year of old Mercury
    By Danny Jones in forum Mercury Mariner Outboard Archive
    Last Post: 07-06-2007, 07:56 PM
  3. What year Mercury 98 HP
    By Stu Lawson in forum Mercury Mariner Outboard Archive
    Last Post: 03-20-2007, 12:44 PM
  4. What year is my 98 Mercury
    By jordan in forum Mercury Mariner Outboard Archive
    Last Post: 10-21-2006, 01:01 AM
  5. Mercury 8hp year
    By zippy in forum Outboard motors archive 2000-2004
    Last Post: 09-01-2002, 04:54 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
