Results 1 to 7 of 7
  1. #1
    Join Date
    Apr 2009
    Location
    Corydon, IN,
    Posts
    1
    Default "We just got our 1998 sea ray,
    "We just got our 1998 sea ray, with 3.0L and alpha 1. We took it out on the water, boat starts and runs fine on muffs. It will rev 4500+ rpms. Put it in water, try to go, starts out like it is going to take off, gets to about 1700 rpms and that is it. Does not miss, does not sputter, just acts like that is all the power it has....have changed to smaller prop, cleaned carb, emptied fuel tank and put in new fuel...could it be accelerator pump or is it ign. prob. How do I check those?"
  2. #2
    Join Date
    Oct 2006
    Location
    Sherwood Park, Alberta, Canada
    Posts
    405
    Default Darin wallot Check and make s
    Darin wallot
    Check and make sure your choke and throttle plates are opening all the way.
    Bert
  3. #3
    guest's Avatar
    guest Guest
    Default "Not the accelerator pump, tha
    "Not the accelerator pump, that's only in use when the throttle is being applied.
    A few questions. Is this boat new to you or do you know it will run up more than it does? Did changing the prop make any change at all? By smaller prop do you mean in pitch size? Is the boat being used in the same area? (wasn't transported from sea level to 5000ft above) Have you checked for a false bottom full of water? Is the engine missing under load?
    This information may help tell what problems you are having."
  4. #4
    Join Date
    Jan 2009
    Location
    friendly , wv, usa
    Posts
    460
    Default im not sure id rev that motor
    im not sure id rev that motor to 4500 rpm out of water be careful
  5. #5
    Join Date
    Sep 2008
    Location
    , Ontario, Canada
    Posts
    51
    Default "I've had this problem a c
    "I've had this problem a couple of times on 2 different boats, two times it was a dirty/old fuel/water seperator, one time one of the fuel hoses came loose on the suction side, make sure the filters are screwed on tight."
  6. #6
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,224
    Default compression test the engine
    Factory Manual Best, Seloc 2nd best, Clymer if you're desperate.
  7. #7
    Join Date
    May 2009
    Location
    See above, North Carolina, THE UNITED STATES OF AMERICA
    Posts
    1
    Default "My Galaxy with a 898 Mercruis
    "My Galaxy with a 898 Mercruiser, and my VW dune buggy BOTH did this..I found it was the ignition coil leaking off idle RPMS. Idle was fine, just wouldn't go over a certain RMP..look at it at night and you will see sparks around the wire tower..or if your drunk a bit, touch the coil tower and see if it zaps the beejeebers out of you..It's best to get a different drunk than yourself though..heh heh Try a new cheap auto parts coil and I bet it will fix it. I am using ACCEL super coils from WWW.SUMMITRACING.COM .They sell a lot of marine stuff now ! CHEAP !"
Similar Threads
  1. 2000 Regal 1700 175 hp Xr2 Jet boat running issue
    By niteltsdjs in forum Mercury Mariner Outboard Forum
    Last Post: 05-29-2010, 06:36 PM
  2. 89 bayliner 1700 30
    By mkbrwn in forum Mercruiser Sterndrive Archive
    Last Post: 06-07-2009, 07:05 PM
  3. 1998 225 HP Mariner Sluggish Under Load between 1750 and 2200 RPMs
    By gagdavis in forum Mercury Mariner Outboard Archive
    Last Post: 06-27-2008, 09:11 PM
  4. 25 hp 1983 Evinrude misses under load at high rpms
    By Drew Logan in forum Outboard motors archive 2000-2004
    Last Post: 08-02-2002, 06:07 PM
  5. b84 Evinrude Boggs down under load wonbt exceed 1700 RPM
    By cashboat in forum Outboard motors archive 2000-2004
    Last Post: 07-30-2001, 11:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
