scuba_biker_trash
"Hi, I am sure this question h
"Hi, I am sure this question has come up many times but it is hard to look at over 44000 posts to find the answer. I have a 115 Johnson Md#J115TLCRD that will not run at full throttle under load unless I hit the primer/choke then it will only run about 3800 Rpm. I have cleaned and rebuilt both carbs, fresh hi-test gas, cleaned and replaced 2 stroke oil, new fuel supply hose, replaced the impeller, t-stats and spark plugs. I have also checked compression, they were with in 10 lbs of each other. I have also checked all the hoses for the fuel and oil system, there were no leaks or bad hoses. When I had it out in the water under load it will idle and run fine all day long under 2000 Rpm but when I go to wide open it feels like it bogs down and when I hit the primer it takes off and planes out. It will rev up fine in the water under no load. I have also tried to squeeze the gas bulb but it was firm and didn't have any effect on the way it runs. So what do I check now?"
