"lined up the belt and gears,
"lined up the belt and gears, then checked the plug wires for proper connection, my understanding is that on the cap there is a number 1. starting clockwise from the 1 should be the #1 wire correct? so I set the wires from there 1342 firing order, started the boat and got backfire through the carb with no start, did this several times, tried turning the dist. did not start at all, just kept backfiring through the carb. should I at this point remove the distributor and realign? My question is that if the belt and gears are correct and the wires are correct what will taking the dist. out of the block do? Just need to understand what i am doing before I do it. thanks, I think I am almost there."
