Gas tank primer bulb
bw94
"is the gas tank primer buld s
"is the gas tank primer buld supposed to be hard while the engine is running. my motor will only run for a few minutes, then spits and sputters and dies. hard to restart"
"no...w/fuel flowing thru it,i
"no...w/fuel flowing thru it,it wont be....only hard,..when every thing,is static...no flow..optimum,position,of primer bulb..level,or slightly up towards eng...."
"The bulb is on the suction si
"The bulb is on the suction side of the fuel pump...the only time it is hard is when you initially pump it before the engine starts....if it collapses completely when the engine runs, there is a restriction in the tank or hose or the vent is not open"
"If you can keep the engine ru
"If you can keep the engine running by pumping the bulb suspect defective fuel pump. BUT check for obstructions in the fuel line, tank venting and for air ingress into the fuel line (esp at the connector)"
