"I'm running a fresh water
"I'm running a fresh water cooled system which will be cooling my manifolds & riser blocks as well. Obviously I have to use block off gaskets between the blocks & risers, but should I use a stainless block off plate sandwiched between two gaskets or is the one gasket itself sufficient?
Thanks!"
Thanks!"
