Results 1 to 7 of 7
  1. #1
    Join Date
    Apr 2009
    Location
    Melbourne, Victoria, Australia
    Posts
    4
    Default "Hi All, Does anyone out th
    "Hi All,
    Does anyone out there have a Mercruiser 470 Wiring Diagram please.
    This is an urgent matter - I want to go fishing!!
    my email is [email protected]
    Kind regards,
    Geoff"
  2. #2
    Join Date
    Jan 2008
    Location
    Posts
    106
    Default "Geoff, Just google
    "Geoff,
    Just google it. You should be able to find what your looking for. Not sure what year you have, but i got a 1980 470, and it's pretty basic."
  3. #3
    Join Date
    Apr 2009
    Location
    Posts
    4
    Default "Hi, Thanks for the reply,
    "Hi,
    Thanks for the reply, I can't get anything on google. I did that first and could not believe that there was nothing there - then again it may be me. I think my stress level is hitting extreme - it is just too long since i went fishing.
    Thanks,
    Geoff"
  4. #4
    Join Date
    Jan 2008
    Location
    Posts
    106
    Default "Geoff, try the search at the
    "Geoff, try the search at the top of this page. By the way, what part of the wiring are you looking for?(starter, ign., trim,?) It may be easier if you narrow your search down."
  5. #5
    Join Date
    Apr 2009
    Location
    Posts
    4
    Default "Ed, Not exactly sure, most
    "Ed,
    Not exactly sure, most proberly ign, but I have a number of leaks/shorts. Battery drains quickly and spark is very weak and engine won't start. As with most older boats it has had a number of running repairs, and as usual some not done so well. What the main difficulty I am having is following the wiring from point to point which is taped together with other wiring - using miles of tape. there is only a few colors used and it makes it eaiser if I know where it goes to (or ment to go to). i have not had this boat for long and I am sure the previous owner has quite a number of wires connected to the wrong points, as well as being mixed up with other wiring.
    Geoff"
  6. #6
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default "try here [url=""]http://fo
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  7. #7
    Join Date
    Apr 2009
    Location
    Posts
    4
    Default "Hi All, I could not get th
    "Hi All,
    I could not get the iboats site to open. i have found another site with all the manuals on in PDF;
    http://marine-engines.wikia.com/wiki...ervice_Manuals
    Thanks to all,
    Geoff"
Similar Threads
  1. Replies: 6
    Last Post: 09-19-2010, 11:12 PM
  2. Mercruiser wiring diagram
    By cruisers00 in forum Crusader Marine Archive
    Last Post: 02-24-2009, 10:22 PM
  3. Wiring diagram mercruiser 1986 350
    By cruisers00 in forum Mercruiser Sterndrive Archive
    Last Post: 02-23-2009, 12:59 PM
  4. Need Mercruiser Model MCM 37 litre 4cyl solenoid wiring diagram
    By ba_50 in forum Mercruiser Sterndrive Archive
    Last Post: 01-21-2009, 11:29 AM
  5. 165 Mercruiser Wiring diagram
    By Justin Hrichena in forum Mercruiser Sterndrive Archive
    Last Post: 05-22-2006, 11:47 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
