Click for Chrysler parts and manuals!
Results 1 to 6 of 6
  1. #1
    Join Date
    Sep 2008
    Location
    Brisbane Australia
    Posts
    135
    Default "I have a spare six cyl fwc ma
    "I have a spare six cyl fwc marine motor, not in boat and wishing to put it in long term storage. It is presently complete and in a running condition. Would appreciate any thoughts on what to do."
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,557
    Default "Change the oil. Pull the plu
    "Change the oil. Pull the plugs, squirt lots of oil in each cylinder while wheeling it over, then seal up the intake and exhaust openings tightly with duct tape.
    Jeff
    PS: A good idea is to turn the flywheel a bit every month or so. They do that with machinery in storage."
  3. #3
    Join Date
    Sep 2008
    Location
    Brisbane Australia
    Posts
    135
    Default "Jeff, I was also planning to
    "Jeff, I was also planning to make a metal plate to cover the in/out openings. Gasket used as the template. This would compress the duck tape hence acting as a gasket, could also use the original gasket. Removal of the thermostat which will allow water mixed with anti freeze to remain in water pump, all hoses to be extended to the approx height of surge tank. I do not have to winterize. Remove all oil. New oil filter. The new oil was going to be machine oil. Planning to remove the dip stick and insert a clear plastic hose to reach the height above the tappit cover. Then fill it up with machine oil, right to the top of the tappit cover.the valves would allow the oil to enter the cylinder and will weep through the rings. The oil would progressively find it own level. The clear plastic hose would act as a oil level indicator. Turning the motor would be by manual application of a wrench. Do you think i could develop oil lock? Like hydro lock! Keep in mind oil will be present both under and above the pistons. The pressure generated above the piston has no release point. The pressure in the crank region is released into the tappit region and via the dip stick holder. I can remove the porcelain from the s/plugs and fashon hoses to dump into the tappit cover. How does all of this sound? Machine oil is not expensive. This motor could be stored for years. Frederick"
  4. #4
    Join Date
    Mar 2007
    Location
    West Hartford, CT,
    Posts
    64
    Default "Frederick, If you're g
    "Frederick,
    If you're going to consider all that, maybe you can consider this as well. Find a plastic tote with a tight lid large enough to contain your engine then crate/palletize it for strength. Remove plugs and openings then immerse engine into machine oil. This should keep it from corroding from the inside out and vice-versa.
    my $0.02, keep the change.
    ,Noel."
  5. #5
    Join Date
    Sep 2003
    Location
    Posts
    15,557
    Default "Boy, are you gonna have a hel
    "Boy, are you gonna have a hell of a time getting it to run again with all that oil seeping through into--everywhere!
    Good plan, though.
    Jeff"
  6. #6
    Join Date
    Sep 2008
    Location
    Brisbane Australia
    Posts
    135
    Default Thank You Jeff and noel. Fred
    Thank You Jeff and noel. Frederick
Similar Threads
  1. Replies: 1
    Last Post: 10-26-2010, 07:36 AM
  2. Long Term Storage
    By mainliner61 in forum Yamaha Outboard Forum
    Last Post: 02-04-2010, 04:37 PM
  3. Long term storage pickling and fogging outboard
    By bbaker in forum Honda Outboard Forum
    Last Post: 11-10-2009, 04:40 PM
  4. 40hp Force fairly new question on long term storage
    By discobayken in forum Chrysler Force Outboard Archive
    Last Post: 07-24-2007, 06:08 PM
  5. Long Storage New Motor Start Up Tips Merc 470 37L
    By eriku19 in forum Mercruiser Sterndrive Archive
    Last Post: 06-17-2007, 02:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
