Results 1 to 2 of 2
  1. #1
    Default "What would be the symptoms of
    "What would be the symptoms of a bad carb float?
    I ordered a new float chamber and cleaned the carb up real good. Put the carb back on the engine and started it, and everything seemed to work great. I did not run the gas out of the engine, and today the engine is doing the same thing it was. It will start, idle up, and then bogged down.
    Could it be the float losing its buoyancy after soaking up fuel overnight???
    It is the only thing around the carb i have not"
  2. #2
    Join Date
    Feb 2001
    Location
    Central West Florida
    Posts
    14,280
    Default Tim.... Go back and stick with
    Tim.... Go back and stick with your original post so that all members know the history of your problem. Duplicate posting brings forth confusion.
    We occasionally have questions. If you fail to answer, it may affect ours.
Similar Threads
  1. Float for my carb
    By chuck4412 in forum Chrysler Force Outboard Forum
    Last Post: 05-01-2009, 11:34 PM
  2. Carb Float
    By mopar_nocar in forum Johnson Evinrude Outboard Archive
    Last Post: 07-09-2008, 06:52 PM
  3. Float Level or Float Drop
    By maxtor in forum Mercruiser Sterndrive Archive
    Last Post: 07-16-2007, 09:04 PM
  4. Carb float
    By adam blantz in forum Suzuki Outboard Archive
    Last Post: 07-08-2007, 08:07 PM
  5. Carb Float Setting
    By rkersh409 in forum Johnson Evinrude Outboard Archive
    Last Post: 02-28-2007, 01:18 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
