"Actually they did. The gauges
"Actually they did. The gauges I put in are Livorsi. They use a 433/17 ohm sender which is what merc uses. The gauges being replaced were VDO. You purchased their gauges for either 240/33 ohm senders which is US Range standard. That is what is currently on my Crusaders, or you could get VDO's senders that are at 10/180 Ohm.
Seeing that Livorsi made their gauges to match Mercs 433/17 ohm senders I need to change the senders.
I just need to know the thread size. Water temp senders from Livorsi come in 3 different sizes, 1/8, 3/8, and 1/2. Just need to know what Crusader used."
