"1. Before you begin, make sur
"1. Before you begin, make sure the battery is fully charged
2. Unplug the coil connector
3. Remove all plugs and examine them carefully for signs of a problem
4. Screw the compression gauge into the plug hole
5. Press the gas pedal to the floor to open the throttle plate, and keep it at WOT (wide open throttle) for as long as you’re cranking
6. Turn the ignition to the ON position, and hold it there for a count of four revolutions (do not turn the key on-and-off four times). On each rotation, the gauge needle will jump slightly less than the previous one.
7. The last number the gauge jumps to is the compression for that cylinder.
8. Repeat for each cylinder.
Update: It may take more than 4 revolutions to get a stable reading; crank for up to 10 seconds or until the needle stabilizes, whichever comes first.
Note: If your battery is weak, the engine will turn over slower and give you lower readings.
anything over a hundred is good readings of 120/130 are excellent,yes clips are good,just dont hold it and stand in the water (i did that once)
