Results 1 to 23 of 23
    Jun 2008
    setauket, ny, usa
    94
    Default "Drilled & tapped my new 1
    "Drilled & tapped my new 1409 Edelbrock to accept PVC hose. Used a 17/64 drill bit & a 1/8 NPT tap. A very, very straightforward & simple procedure. I have tried to attach some pix that I hope will help others in the future. Hope they are readable."
    Jun 2008
    setauket, ny, usa
    94
    Default Ooops... pix didn't upload
    Ooops... pix didn't upload... HELP!
    Sep 2003
    New Tripoli, PA, USA!
    15,556
    Default "Tell us the truth, Mike: How
    "Tell us the truth, Mike: How nervous were you drilling the hell out of that brand new, $$$ carb!
    Jeff
    PS: Pix must not be .bmp format and have to be realllllly tiny to upload. Send me the file, if you want, and I'll fix it up for you."
    Jun 2008
    setauket, ny, usa
    94
    Default "Hi Jeff... I was pretty nervo
    "Hi Jeff... I was pretty nervous about drilling that beauty... Once I realized that the hole does not compromise the fuel area, the heart palpitations stopped... Thanx for the offer... I'll try & figure out how to send the file to you... }"
    Mar 2008
    Bruford SC , U.S.A.
    325
    Default Click on his username and then
    Click on his username and then his e-mail. You can then attach the file and send it. Otherwise you could try and shrink the photo down to the size of a postage stamp and upload it that way.
    I ask Edelbrock why the marine carb didn't have a port when the street carb does but he couldn't tell me other than there built to marine regs.
  6. #6
    Apr 2008
    52
    Default "Mike, You can use one of man
    "Mike,
    You can use one of many free picture hosting sites available on the web. I use Picasa only because I am familiar with it. You can have private or public albums that you post the link on your message.
    Eddie Zuskin"
  7. #7
    Jun 2008
    Island Heights, NJ,
    2,799
    Default This PVC hose is for ???
    Capt Bob
    1969 23ft ChrisCraft Lancer
    Merc 5.7L 260HP/ Volvo 280
    1972 22ft Bristol
    Honda 7.5HP 4 stroke Long shaft
  8. #8
    Sep 2003
    15,556
    Default "Keeping moisture out of the e
    "Keeping moisture out of the engine, moisture that forms acid and slug much faster than in a street car application. A working PCV system is essential in a marine engine or....
    B-O-A-T
    Jeff"
  9. #9
    Jun 2008
    Island Heights, NJ,
    2,799
    Default "Yes it is... However, he said
    "Yes it is... However, he said PVC = Poly Vinyl Chloride... Personally I'd be leary of drilling holes and modifying a marine certified carb for warranty and insurance reasons. If I wanted crank venting in that scenario, I'd just clip the crank (or rocker cover) vent line(s) to the flame arrestor inlet."
    Capt Bob
    1972 22ft Bristol
  10. #10
    Mar 2008
    Bruford SC , U.S.A.
    325
    Default The old AFB's had the port
    The old AFB's had the port but something has changed since then probably. I've seen arrestor's with 2 hose attachments for that reason I suppose.
  11. #11
    Jun 2008
    setauket, ny, usa
    94
    Default R.A.F. Sorry about the typo: P
    R.A.F. Sorry about the typo: PVC vs PCV ( Positive Crankcase Ventilation ) valve... Mike...
    E.Z. Thanx for the advice... I didn't have the patience to try & resize them... Mike...
    Conqueror... I took your advice & e-mailed them to Fastjeff... Mike...
    Fastjeff... I e-mailed you the pix... Mike...
  12. #12
    Sep 2003
    15,556
    Default I e-mailed you back. Je
    Jeff
  13. #13
    Sep 2003
    15,556
    Default "For those of you drilling the
    "For those of you drilling the holes for the PCV fitting, you got to drill UP as well to open a passage. See the photo of Mike's work below.
    Jeff "
  14. #14
    Jun 2008
    setauket, ny, usa
    94
    Default "Carb. installation complete l
    "Carb. installation complete less final choke wiring... Ran engine yesterday on the hose... Vast improvement over the old Carter AFB... Attached are some pics... The one with the arrow shows the bottom of the carb with the hole that needs to be drilled, in relation to the PCV fitting, prior to drilling... See Jeff's post... As stated previously, it is a simple procedure, just proceed slowly... I used a 17/64 bit to drill both holes, & a 1/8 NPT tap for the PCV fitting...Thanx to everyone for your help... Mike...1/8NPT tapped hole"">PCV fitting installed"">PVC fitting installed"">17/64 Hole for PCV fitting passage
  15. #15
    Jun 2008
    setauket, ny, usa
    94
    Default Forgot to mention... It is a 1
    Forgot to mention... It is a 1409 Edelbrock MARINE carb.
  16. #16
    Mar 2008
    Bruford SC , U.S.A.
    325
    Default Super job....! You would never
    Super job....! You would never know it didn't come that way.
  17. #17
    Jun 2008
    setauket, ny, usa
    94
    Default "Conqueror: Thanx for the kin
    "Conqueror: Thanx for the kind words... Were it not for the info that was available on this board, I would not have known exactly how to proceed... I think the 1409's are made lacking a PCV port because the hose/s are now attached to the flame arrestor...Don't have a clue as to the difference... Finished wiring the choke today... attached at the 12V side of the Ballast Resistor... Replaced defective, rotted wiring at the same time & the engine seems to start better & run much better on the hose... Could run differently under a load... Will post some pix of the final install later... Mike..."
  18. #18
    Jun 2008
    setauket, ny, usa
    94
    Default "Attached are some pix of the
    "Attached are some pix of the final install... being a cheapskate, I enlarged the opening in the original flame arrestor, & was able to use same... Gotta clean up those valve covers... Mike..."
  19. #19
    Jun 2008
    Island Heights, NJ,
    2,799
    Default "To further confuse matters, m
    "To further confuse matters, my 260 HP 5.7L Merc w/2bbl has one of each... A hose to the carb base and one to the arrestor! I do believe the rationale for that setup is to allow under certain engine operating condition, i.e., idle or other low blowby situations, air flow INTO the hose at the arrestor, thru the engine and back out into the carb base, which is at a vacuum at idle.
    Under high blowby conditions, with low intake manifold vacuum, there is always a slight vacuum at the flame arrestor hose. One way or another... it still sucks :-)"
    Capt Bob
    1972 22ft Bristol
  20. #20
    Jun 2008
    setauket, ny, usa
    94
    Default "R.A.F. Check out the first p
    "R.A.F. Check out the first pic on the above post. Mine has 2 hoses as you have described. 1 is from a breather attached to the port valve cover, going to the flame arrestor. The other is from the PCV valve located on the starboard valve cover. Mike."
  21. #21
    Sep 2003
    15,556
    Default The hose to the flame arrestor
    The hose to the flame arrestor is for the air that's coming INTO the engine. The PCV hose takes the air OUT via suction.
    I too reused the old flame arrestors. Maybe we're related!
    Jeff
  22. #22
    Jun 2008
    setauket, ny, usa
    94
    Default My previuos post is in error..
    My previuos post is in error... The PCV hose connected to the FRONT of the carb. attaches to the PCV valve located on the PORT valve cover... The hose connected to the flame arrester attaches to a breather located on the STARBOARD valve cover... Sorry for the mix-up...
    Jeff... I think frugality has many kin folk...lol... Mike...
  23. #23
    Jun 2008
    setauket, ny, usa
    94
    Default Never mentioned: 1409 Edelbroc
    Never mentioned: 1409 Edelbrock. The install was on a 1981 Chrysler 318.
    Mike...
  1. Got the Edelbrock 1409 and ready to install,
    By SeaWay in forum Crusader Marine Engine Forum
    Last Post: 08-31-2010, 12:43 PM
  2. Edelbrock 1409
    By mictat2214 in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 06-05-2010, 09:55 AM
  3. Edelbrock 1409 help tuning
    By aday_in_nh in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 09-21-2009, 06:45 PM
  4. Edelbrock 1409 PCV DrillingTapping
    By bogdenz in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 07-02-2009, 04:36 PM
  5. 1409 Edelbrock
    By agitator in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 04-28-2009, 10:53 PM
