Results 1 to 8 of 8
  1. #1
    Join Date
    Apr 2009
    Location
    Logan, Ohio, USA
    Posts
    3
    Default "Hi everyone, I've got a s
    "Hi everyone, I've got a sterndrive outdrive and reverse isn't working. I'm a pretty good automotive mechanic however outdrives are new to me. I've got it apart but not really sure what to check. It is an electric shift and I think i've got the reverse coil out. I thought I read somewhere I could check the ohm reading of the coil to see if it is good. What i'm really looking for is some guidance on things to check and troubleshooting. I'm sure i'm not the only one with this issue so any help would be greatly appreciated. Thanks in advance for your feedback."
  2. #2
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,224
    Default I would've checked the wir
    I would've checked the wiring and everything before taking it apart. The reverse coil rarely fails. Don't spend enough time in reverse over the life of a boat to cause it to fail.
    4-7 ohms typical.
    Factory Manual Best, Seloc 2nd best, Clymer if you're desperate.
  3. #3
    Join Date
    Apr 2009
    Location
    Logan, Ohio, USA
    Posts
    3
    Default "Ya... good point.. I actually
    "Ya... good point.. I actually did check the wiring but wasnt sure which one was for forward and which one was reverse. Now that its apart, i'll check the coil then put it all back together and check it again. Thanks for your feedback."
  4. #4
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,224
    Default what kinda lube you using?
  5. #5
    Join Date
    Apr 2009
    Location
    Logan, Ohio, USA
    Posts
    3
    Default what do you suggest? I was go
    what do you suggest? I was going to use a marine lub.
  6. #6
    Join Date
    May 2007
    Location
    Kawarthas
    Posts
    3,224
    Default "that could be your problem. T
    "that could be your problem. There is a special high electrical resistance lubricant for electric shift lower units called "Type C".
    Regular gear lube conducts electricity.
    As I'm sure you've discovered, there are uninsulated electrical connections in the l/u.
    Might want to snag an OMC manual from eBay or at least a Seloc one from this site.
  7. #7
    Join Date
    Nov 2006
    Location
    , Ontario, Canada
    Posts
    292
    Default "You can still buy Type C at C
    "You can still buy Type C at Canadian Tire, in Canada, or at the Marine Dealer. I assure you, the latter is more expensive."
  8. #8
    Default "[b]1973 omc electric shift ca
    "1973 omc electric shift can any one help with this problem took the bayliner out the other day shifted into forward went fine for about 75 yards, it reved up like i took it out of gear and it would not go in forward any longer it shifted into reverse fine any ideas would really help thank you "
Similar Threads
  1. 1976 350 sterndrive?
    By goku2246 in forum Mercruiser Sterndrive Forum
    Last Post: 06-08-2010, 01:02 AM
  2. Parting out 1976 OMC 175 ford 302 and sterndrive
    By mrdjflores in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-25-2009, 01:04 AM
  3. 1976 OMC Sterndrive Questions
    By mackinthebox in forum OMC Sterndrive and Inboard Archive
    Last Post: 09-02-2008, 06:58 PM
  4. Johnson 55HP 1976 Reverse Problem
    By markmck in forum Johnson Evinrude Outboard Archive
    Last Post: 08-15-2007, 02:41 PM
  5. 1976 omc sterndrive oil leaking from water intake
    By robw357 in forum OMC Sterndrive and Inboard Archive
    Last Post: 03-12-2007, 11:01 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
