Kad 43 compressor clutch slipping
antsinupants
I have a Kad 43 i have replace
I have a Kad 43 i have replaced the complete compressor clutch and belt.
but i still have a slipping clutch
I have adjusted the running clearance of the pully faces. the belt is tight.
i think it is not getting enough power to the magnet? any ideas how to check the output to the magnet?
also what controls the compressor?
many thanks rob
Can you rotate compressor by h
Can you rotate compressor by hand? Must spin freely or just slight drag. Unit is controlled by a relay box under cover and an rpm sensor above raw water pump.
thanks for the reply
i have
i have now replaced all the belts. things are all good now. the small belt that takes drive from the crank was worn out.
