2004 Johnson 115hp lower unit
shiner
"How much lube does the lower
"How much lube does the lower unit of a 2004 Johnson 115hp hold, Going to help some-one change
the lube and want to make sure I have enough on hand. Thanks"
"About 1 quart!
115
"About 1 quart!
115 1990-up 26 oz.
115 4-stroke 2003-up 36 oz.
115 60V4 EL, GL, SL 1995-up 31 oz.
115 60V4 EX, SX, V6 G/C 1995-up 34 oz."
"115 60 V4 EL, GL, SL 1995-Th
"115 60 V4 EL, GL, SL 1995-Thru 31
115 60 V4 EX, SX V6 G/C 1995-Thru 34
get a lil more than a qt......"
Thanks John Parker and jwbmari
Thanks John Parker and jwbmarine! I had picked up 2 10oz tubes but I guess I'd better get some more.Neither lower unit or crankcase has ever been changed and just wanted to make sure I had everything on hand. Thanks again!
"I thought you fill it until i
"I thought you fill it until it comes out the top hole, then put the top plug in and give it a few more pumps."
