"Robert, you can (boost
"Robert, you can (boost) the 2001 9.9 to a 15 horse. The 1995-on 9.9/15 horse shared a powerhead.
You need to replace the carb with one from a 15 horse model (about 225 bucks new from Merc)
and pull the powerhead and replace the exhaust plate and tube (which comes as a single unit - about 60 bucks)
and of course throw in a new exhaust plate gasket and powerhead base gasket, cheap at about 15 bucks for the pair).
And once you have done all that you will get almost 2 more mph out of your rig at wide open throttle (actually the best I did in tests that I performed was 1.8 mph, but I guess 2 is pretty close) and you will burn 15% more gas all the time.
You gotta ask yourself, is 2 mph worth 300 bucks and a few hours of your time?
Or you could do it and lie to yourself about how much more power your rig has.
Moving from a 9.9 to a 15, even though it's a 50% horsepower increase, just doesn't not make the kind of difference most think it will.
If you want a change you will actually see/feel, you would have to move from a 9.9 to a 25 horse at minimum....."
