Water pump when and how much
lamiglasmike
"I have a 2004 Honda 150 (
"I have a 2004 Honda 150 (bought new in 05)with 133 hours on it. I spoke with the dealership about the water pump maintenance, asked should I replace it or not? There answer was it should be fine till 200 hours, because I rinse very well after each use and also trailer the boat. The owners manual says after 200 hours or two years.
Your thoughts?
Just curious on how much I should expect to pay if done by a dealer.
Thanks, Mike"
"A good 10 minute (minimum
"A good 10 minute (minimum) fresh water flush is the best thing you can do to keep the cooling system at peak performance. It should be inspected every 200 hours and I always replace the impeller at inspection time, even though it's seldom necessary. Nothing else needs replacement unless you see damage or significant corrosion."
"Like you I flush my motor at
"Like you I flush my motor at the end of each day, with fresh water, and trailer the boat.
I replace the water pump two years, regardless of the number of hours.
The cost estimate this year is $250 (on Cape Cod)."
"I'm leaning towards repla
"I'm leaning towards replacing the water pump. I have heard from a few people already and the majority says to change it out. $250.00 does not sound that bad! I'm going to look into some prices next.
Any other info is much appreciated.
Thanks, Mike"
