Click for Chrysler parts and manuals!
Results 1 to 6 of 6
Thread: M440 temps
  1. #1
    Join Date
    Jan 2009
    Location
    seattle, wa
    Posts
    90
    Default "Paranoia? M440 FWC. Heads red
    "Paranoia? M440 FWC. Heads redone last year, new risers and elbows. Heat ex boiled out, manifold looked good, new thermostat.
    I bought a new IR thermo gun and shot my Port engine for fun. Are the following temps within reason?
    From front of engine to rear (to include middle of log) temps.
    Outboard log; 202, 196, 185
    Inboard log; 195, 190, 185
    Expansion tank at cap; 195
    Thermostat housing; 160
    Elbows on top of risers; 120
    Hoses; 140
    This is at dock idle. If it's hot, would the raw water flow increase underway, thus bringing temp down a few? Impeller was new 2 yrs ago. Not many hours on it, except sitting while engines were put back together last year.
    Thanks"
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,471
    Default "Seems reasonable to me. The
    "Seems reasonable to me. The motor side runs hotter due to the t-stat setting, while the raw water side is about right as well. Much more water flows through as the revs come up, but I'd keep an eye on it, just to be sure.
    Smart move buying the temp gun. Have you measured the cat or the dog with it yet?
    Jeff"
  3. #3
    Join Date
    Jan 2009
    Location
    seattle, wa
    Posts
    90
    Default "No, but they could be next. N
    "No, but they could be next. Now that I have one, can't imagine how I got along without one. Now I know the temp of my garage floor. I can finally sleep at night!
    Thanks Jeff!"
  4. #4
    Join Date
    Sep 2003
    Location
    Posts
    15,471
    Default "My wife loves to play with ou
    "My wife loves to play with our temp gun, taking the temps of all kinds of things. Fine tool AND play thing!
    Jeff"
  5. #5
    Join Date
    Jul 2006
    Location
    Redmond, WA, USA
    Posts
    216
    Default I have recorded all my temps a
    I have recorded all my temps at a 3000 rpm cruise and keep them in a log to compare with the next set of readings I take. I don't remember what the numbers are without looking at the log. Check the shaft log temps and alternater bearings also.
    Dan
  6. #6
    Join Date
    Sep 2003
    Location
    Posts
    15,471
    Default "Remember: Even if you truly
    "Remember: Even if you truly are paranoid, there can be someone following you.
    Jeff"
Similar Threads
  1. Engine temps rising
    By cragonese in forum Volvo Penta Gas Archive
    Last Post: 06-02-2009, 01:11 AM
  2. 43 lx exhaust temps
    By mike1970 in forum Mercruiser Sterndrive Archive
    Last Post: 10-27-2008, 07:53 PM
  3. Exhaust riser temps
    Last Post: 08-22-2008, 07:40 PM
  4. 88 30 Cobra Temps up amp down
    By bilyclub in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-29-2007, 10:09 PM
  5. High exhaust temps
    By mvoutbound in forum Other Diesels Mfgs and General Diesel Questions
    Last Post: 05-09-2006, 01:46 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
