Click for Suzuki Manuals, Parts and Model Guides!
Results 1 to 3 of 3
Thread: DF 300
  1. #1
    Default "Turned engine on and a beepin
    "Turned engine on and a beeping noise started--"check engine light 7-5" came on then went off after I started fiddling with it, still beeping though. Any ideas????"
  2. #2
    Join Date
    Aug 2008
    , VA, USA
    Default "I believe this is a standard
    "I believe this is a standard low voltage message. Mine did this three weeks ago, followed by a control comm error and it is still in the shop."
  3. #3
    superpole727's Avatar
    superpole727 Guest
    Default 7-5 code is DBW system. Just d
    7-5 code is DBW system. Just did one. It's power to BCM circuit. Someone scabed a wire in at the key switch and did a hack job. The constant surge fried the main relay on the stbd engine. It took a while to locate the problem everything was tied up nice and neat. They just didn't know how to make a good connect. Everglades 290.
    Tell them to chk the main relay on the engine!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
