"Ricardo, not "locking hor
"Ricardo, not "locking horns" with anyone here, just exchanging thoughts or philosophies.
The exhaust outlet in the 280 is about 6 square inch, and the restriction that may be caused by the bellows flapper is not substantially different from the restriction created by the factory installed flapper in the drive outlet. But the effect of the relief holes combined adds another 1.5 square inch (or 25%) to the exhaust, and that added surface becomes your saviour when it comes to preventing excessive back pressure.
Ideally, I agree that there should be no restrictions whatsoever in the exhaust. But also (ideally), water should never be able to reach the cylinders through the exhaust. Back to the real world, where the conditions are far from ideal, one has to make a balanced approach and consider the pros and cons of having (or not) a flapper installed. From my perspective, I'd rather prevent damage to the engine by stopping water ingress, and I'd settle for having the flapper installed, especially after not having observed any adverse effects. And if I found that a mechanic had removed the flapper from my boat exhaust without previous consultation, I suggest that loosing me as a customer was the least that would happen, especially if water ended reaching the cylinders.
Right or wrong, that's my take on it."
