Click for Chrysler parts and manuals!
Results 1 to 4 of 4
Thread: FLOAT DROP
  1. #1
    Join Date
    Oct 2007
    Location
    Gananoque, Ontario, Canada
    Posts
    46
    Default Does anyone know what the floa
    Does anyone know what the float drop is supposed to be on an old AFB four barrel with the two idle mix screws on the front as well the larger air screw in between them?
    Mark
  2. #2
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,325
    Default "Not a big deal. Just be sure
    "Not a big deal. Just be sure the floats don't go down too far and jamb in hte down position. Once the carb is assembled and gas appears, the float drop is no longer an issue.
    Jeff"
  3. #3
    Join Date
    Oct 2007
    Location
    Posts
    46
    Default Thanks Jeff. My issue is the a
    Thanks Jeff. My issue is the accelerator pump only works for one ot two squirts then the fuel level is too low.
    And when I put the engine in gear it sputters and dies.
    I am thinking the floats sit too low and are closing off the fuel supply too early.
    The drop on them right now is about one and half inches.
    I think it should be closer to three quarters to one inch.
    Mark
  4. #4
    Join Date
    Sep 2003
    Location
    Posts
    15,325
    Default Whoa! That's float level.
    Whoa! That's float level. Float drop is how far down they fall with the cover off
    Turn the cover upside down. The floats should be about 1/2 inch from the cover.
    Jeff
    PS: Make sure they don't bind on te body of the carb or....
Similar Threads
  1. Mercury 50 hp 1977 carb float level and flot drop adjustment
    By vuk_klek in forum Mercury Mariner Outboard Archive
    Last Post: 05-20-2009, 03:20 PM
  2. Float losing buoyancy What would be the symptoms of a bad carb float
    By tcarpe1 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-21-2009, 12:46 PM
  3. Rpm drop off at wot 150 xp
    By bec in forum Johnson Evinrude Outboard Archive
    Last Post: 12-05-2007, 03:57 PM
  4. Float Level or Float Drop
    By maxtor in forum Mercruiser Sterndrive Archive
    Last Post: 07-16-2007, 09:04 PM
  5. Rpm drop
    By Roger R. in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 06-16-2006, 01:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
