Rubber Lower Mount
smitair17
"What is it for? Its number 1
"What is it for? Its number 18 in the diagram.
Also When in a tank, water comes out from behind it, is this supposed to happen?
Mount
"This is lower engine mount, I
"This is lower engine mount, It absorb vibrations from the engine and keep it off the transom and hull, You can remove the inspection plate to get a good view of it, If you run your boat in salt water this is the number one area for corrosion. I flush this area on my motor with soap water every time I take my Boat out.
Not sure about the water issue you mentioned hopefully its not corrode through the housing. Removing the plate will help"
