"Good compression, flywheel ke
"Good compression, flywheel key looks like new, good blue spark, getting gas. At first it would hit a few licks but would not stay running unless I put it in gear to open the throttle. Now it won't run or even hit at all. Any suggestions? It's doing everything I would expect a good running motor to do but won't hit a lick now. I've check plug several times and pulled starter rope several times with plug out to blow out the cylinder."
