Click for Chrysler parts and manuals!
Results 1 to 8 of 8
  1. #1
    Join Date
    Jul 2006
    Location
    Toronto, Ontario, Canada
    Posts
    35
    Default I have twin 318 Chryslers with
    I have twin 318 Chryslers with 71c transmissions.
    The starboard xsmn is no good.Is it possible to replace it with a port xsmn.
    Join Date
    Sep 2003
    Location
    New Tripoli, PA, USA!
    Posts
    15,556
    Default "I assume you mean with ANOTHE
    "I assume you mean with ANOTHER port transmission. If so, yes, but you'll have to reverse the oil pump.
    Jeff"
  3. #3
    Join Date
    Mar 2009
    Location
    Fredericksburg, Va, USA
    Posts
    8
    Default "Just reversed mine and it was
    "Just reversed mine and it was easier than expected. This is the way I did mine. Pull the transmission off. Pull the four bolts out of the front. Then tap on side of of wrench held up against side of ridge on pump. Mine rotated right around. There are two arrows on pump, you line up the arrow that points the way the engine turns with the appoximate top of the transmission lineing up the bolt holes. It is not a perfect 180 turn, but close. Put the four bolt in and torque them down. Marinepart***press.com has a download able tech manual on the transmission. It has the torque specs which I can't recall."
  4. #4
    Join Date
    Sep 2003
    Location
    Posts
    15,556
    Default Wow! I wish reversing the eng
    Wow! I wish reversing the engines was as easy!
    Jeff
  5. #5
    Default No Chitt about that Jeff to ea
    No Chitt about that Jeff to easy. complete rebuild kits are ava. for about 60 bucks parts. Very simple trains. Velvet 1 to 1
  6. #6
    Join Date
    Sep 2003
    Location
    Posts
    15,556
    Default David: Gonna put your name
    David:
    Gonna put your name in my file in case I need trans stuff.
    Jeff
  7. #7
    Default "I also have 3 sets of heads 3
    "I also have 3 sets of heads 3 starters 3 1 to 1 c71", manifolds, risors oil pans and a hundred of other used parts"
  8. #8
    Join Date
    Sep 2003
    Location
    Posts
    15,556
    Default Definitely a resource! Je
    Jeff
Similar Threads
  1. Borg Warner 71C question
    By sammi in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 12-24-2009, 12:54 PM
  2. Borg Warner C2 transmission
    By swelch in forum Marine Transmissions and Reverse Gears
    Last Post: 12-24-2009, 09:25 AM
  3. Borg Warner 72c
    By blasttech1 in forum Miscellaneous marine engine topics
    Last Post: 04-23-2008, 11:45 PM
  4. Borg warner 72c vdrive
    Last Post: 04-08-2008, 05:47 PM
  5. Borg warner transmision to hot
    By just_ed in forum Archive 2002-2006
    Last Post: 07-17-2003, 10:01 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
