"The boat had a 5.4/5.5 error
"The boat had a 5.4/5.5 error code on it the other day, it turned out to be a fuse hooked up to the actuator. We replaced the shift cable because we believed that it locked up and caused the fuse to blow. Now the actuator moves about an eighth of an inch every time we turn the key off and then on. The actuator will not reset into neutral and the starter will not initiate since we put in the new cable. Does it sound like the actuator is done?"
