"I am currently having a tilt/
"I am currently having a tilt/trim problem, the motor will not go up or down. Previously had a problem and replaced relay which fixed it. I noticed this weekend that the tilt/trim was not working right and it eventually quit working. Thinking it was the relays, I changed both and it still doesn't work. I have three switches in the boat that run the tilt/trim and each time I use the switches you can hear the relays click. I checked the hydrolic oil and it is full. What do I check next?"
