"1999 50hp envinrude has low w
"1999 50hp envinrude has low water stream or more like spitting out. Change water pump with out any change in the water stream. Open hole in the motor housing, should there be like a rubber plug with smaller hole to help the back pressure that would help make a good stream coming out.
has not run hot."
has not run hot."
