Click for Bukh manuals!
Results 1 to 3 of 3
  1. #1
    Default "motor lost revs suddenly and
    "motor lost revs suddenly and could only reach fast idle with throttle fully on.replaced fuel filter,checked lines.bled several times till engine ran. Next outing after 40 minutes same problem,any ideas?"
  2. #2
    Join Date
    Jul 2009
    Location
    derby, derbyshire, england
    Posts
    1
    Default "Hi, I have a similar pro
    "Hi,
    I have a similar problem with a bukh dv20. If you have any luck I'd be most interested.
    Regards,
    Peter."
  3. #3
    Join Date
    Oct 2009
    Location
    √ćsafjordur Iceland
    Posts
    1
    Default "Check inside the fuel lift pu
    "Check inside the fuel lift pump, unscrew the top cover and you will see a small wire filter, could be stuck.
    this should be cleaned once a year or with interval of no more than 150 oh."
Similar Threads
  1. 2004 TAMD75P - loss of revs
    By Blue Moon in forum Volvo Penta Diesel
    Last Post: 05-15-2010, 06:01 AM
  2. Bukh DV 18
    By nautiko in forum Bukh
    Last Post: 12-08-2008, 03:26 PM
  3. Bukh DV engine
    By Tommy Petri in forum Bukh
    Last Post: 09-29-2008, 01:28 AM
  4. Bukh DV 24 ME
    By gwb in forum Bukh
    Last Post: 01-02-2008, 12:17 PM
  5. Bukh engine
    By onokaya in forum Bukh
    Last Post: 03-27-2004, 09:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
