Primer bulb
sticky
"put new bulb on sqeezed it up
"put new bulb on sqeezed it up fired motor,bulb turned flat,motor runs fine,is the bulb bad, thanx"
"u COULD...have a bad ck valve
"u COULD...have a bad ck valve in it....or a fuel restriction,down stream.pull and ck it w/a short piece of hose."
"[i]"or a fuel restriction
""or a fuel restriction,down stream"
Upstream I think! That is between the bulb and the tank, including the pickup strainer, if any, in the tank.
It might just be a very soft bulb though."
You simply have a clog between
You simply have a clog between the fuel tank and the primer bulb locate it and go Boating
