"I've installed a rebuilt
"I've installed a rebuilt 318 in my Trojan F26. I started wiring it back up only to find the markings I made on white tape when I disassembled everything is completely gone.I think I've got everything figure out EXCEPT the battery selector switch. Its a Perko -OFF-1-both-2 switch.The way it came cannot be right! I assume one lead from the hot side of each battery to either side of the switch. Then the common from the switch should go back to the started solenoid??? Is it ok then to tie both battery negative post together and run one ground cable to the block? Just to make sure does anybody know off hand where the three terminals on the charging relay go? The voltage regulator has one plug in lead and one screw on lead, where does the screw on lead go to? Just don't want to fry anything!"
