"Regarding the need for more i
"Regarding the need for more info, maybe...but the ignition systems on these engines is similar enough, that you can easily try some basics first without needing exact model numbers, etc.
However, looking at 1997 150..if the basics don't fix it...then it does appear to be a bit more complicated than my 1996 200 looper.
Frank, post the model number when you can.
The fuse will NOT prevent the engine from generating ignition spark. If it is turning over at proper starter speed...300 rpm or so, and the kill circuits are disabled, it will gen spark.
You can disconnect the boat harness modular plug, straight jump the starter with jumper cables, or use a remote starter switch, and the engine will start (assuming nothing wrong with the ignition system). Since the harness is disconnected, you will have no way to shut it off, except to choke it down with rags over the carbs. So that is a bit dangerous, but it can be tried. With the harness disconnected, the key switch kill circuit is eliminated, also.
Remember, these engines generate their own power to fire the ignition system through the stator and magnets in the flywheel. They need no battery except to turn over the starter."
