M
mudshark08
Guest
"I have a 1976 mercury 850. Wh
"I have a 1976 mercury 850. When moving the throttle/shifter lever it travels about 45 degree's after engauging in foward or reverse before I get any throttle. Also I am only getting 4200rpm at full throttle. I have tried adjusting the cable inside the motor housing with no luck, all that seemed to do is increse the idle speed. Should I try adjusting the cable inside the lever housing ? Please help."
