Intake manifolds
brianmc
Repowering a Marinette with a
Repowering a Marinette with a crate 318 lb. Are there deferences between marine and auto intake manifolds. Can I use a auto eldebrock and put the wedge in.
Hummm.... You'd need to c
Hummm.... You'd need to compare the fittings on both to see if the water neck and etc. are compatible. The Edelbrock and spacer should go without a problem.
Jeff
The edelbrock manifold will fi
The edelbrock manifold will fit but the thermostat housing mount bolts are on a 45 degree angle to the engine centerline. This may force some mods to the housing and plumbing and the engine must be FWC.
What exactly did you mean when you said a "Crate 318"
Joe
"I ran into that thermostat is
"I ran into that thermostat issue too and it's easy enough to work around but since then I noticed the Weiand manifolds are straight across plus they were engineered by the same guy who did the Edelbrock performer series, unfortunately there imported casting...Model number 8007"
