09 115 Check Engine Light
rainman
"I got a 09 115 as a factory d
"I got a 09 115 as a factory demo suppose to "maybe" have an hour or two on it, could even be less... I went out this weekend and tried to follow the break in instructions in the manual, to be on safe side. When I get to 3100-4100 rpm the check engine light comes on with no beeps. Go above 4100 light goes off, below 3000 light goes off. Could this be a warning that I need to stay below 3000 for breakin. I try following the timing instructions for break in but I may be off as I would just look down at the watch occasionally to see how long I'd been running. May not have reached the "3 hour" mark to start going above 3000 rpm... Any advice would be greatly appreciated."
I have the exact same problem
I have the exact same problem with my DF140 purchased in Mear 09. Its still in the shop. What did they do to fix you're problem?
