"I have 1996 120hp Force outbo
"I have 1996 120hp Force outboard. It idles just fine, but runs with little or no power. After running it I find water mixed with gas on the sparkplugs of the bottom two cylinders. When you look in the bottom two cylinders, there is milky fuel over the tops of the pistons. The compression in the cylinders was check and all had about 140psi each. Milky colored fuel comes out of the bottom carburetor when you tip the engine up after use. The top two cylinders look normal. We have checked the fuel supply and there is no water in the fuel. Would anyone have any idea where to start looking? Is this a cracked head, leaky gasket, cracked block? The engine has never been overheated."
