last year had a problem with b
last year had a problem with boat bogging down when accelerating and couldn't get it over 2500 rpm checked all filters and replaced 2 low pressure pumps cleaned vst tank and filter and still did no good.took it to dealer and after being there 3 months they condimed and replaced hpdi pump. took the boat out after the repair and it ran fine . boat set a couple of months since and i took it out this weeked and its doing the same thing. checked the vst tank and filter and it had a little rust in it put it together primed the bulb and have fuel to it but now i cant keep it running. whats the chance ouf 2 hpdi pumps going bad in 8month period. the shop that did the repair also closed up so i cant take it back. also can the hpdi pump be repaired/rebuild thanks for any suggestion or help.
