Results 1 to 10 of 10
  1. #1
    Join Date
    Jun 2008
    Location
    woodbridge, NJ, US
    Posts
    16
    Default "I have a 2000 5.0L Mercruiser
    "I have a 2000 5.0L Mercruiser with a 2 barrel carburetor. I would like to move to a 4 barrel for more power. Appreciate your input as to what modifications are required to the engine to achieve this. Is it a good idea?
    I found a good deal on a reconditioned Rochester brand 4-barrel carburetor that was intended to be used on a GM Crusader 454 Engine- 350 HP. Could this work? See pictures
  2. #2
    Join Date
    Sep 2006
    Location
    SF BAY AREA, CALI, USA
    Posts
    8,649
    Default "You need a manifold i believe
    "You need a manifold i believe, maybe a cam, dunno
    and watch your gas go down twice as quick"
    HUMAN BUILT = HUMAN FIXED
    CERTIFIED MARINE TECHNICIAN
    WWW.JUSTINTIMEMARINE.COM
  3. #3
    Join Date
    Aug 2006
    Location
    SW Ohio, USA
    Posts
    10,396
    Default You'll also need the throt
    You'll also need the throttle cable bracket. That 4BBL looks like it belongs in Davey Jones' locker; get a merc. reman. or a new Holley. You will only get 15-30 more HP.
    If you want more "hole shot" then get a 4 blade prop 1 pitch lower than what you have now.
    What is your current WOT RPM? If you aren't near 4800 RPM then drop the prop pitch or go to an SS prop.
    Fix minor things (replace wear items for preventative maintenance.) that cause major problems before they break.
  4. #4
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,286
    Default "[b]"That 4BBL looks like
    ""That 4BBL looks like it belongs in Davey Jones' locker; get a merc. reman."
    Ayuh,...
    Buy an Edlebrock Performer,...
    They're exact carbon copies of the Merc./ Weber carbs Merc uses..."
  5. #5
    Default "Hi, I see some 4.3 liter V6 m
    "Hi, I see some 4.3 liter V6 mercruiser engines rated 205hp verses the standard 175hp.I have two short blocks,one is a 1987 the other is a 1990.Are the blocks the same , as well as the heads,and is the hp. difference just the carb. and manifold?Thanks"
  6. #6
    Default "Sorry,I goofed,I was reading
    "Sorry,I goofed,I was reading yours and went straight to post instead of starting a new disscussion."
  7. #7
    Join Date
    Mar 2009
    Location
    Lowell, MA
    Posts
    1,217
    Default "Hi Ray, hopefully i'm not
    "Hi Ray, hopefully i'm not to late, but a 454/350hp 4bbl carb wont work because the Metering Rods and jets would be too much for the 305ci 220hp engine. You can have it re-jetted if you already own it."
  8. #8
    Join Date
    Mar 2009
    Location
    Lowell, MA
    Posts
    1,217
    Default "Hi Ray, also the other issue
    "Hi Ray, also the other issue is Choke, it doesn't look like it has an electric choke and the one from your 2bbl carb wont bolt up. then you'll also need to swap out your intake manifold (unless it is a 4bbl "speadbore" type)"
  9. #9
    Default "Ray, Listen to Brian. He is
    "Ray, Listen to Brian. He is correct."
  10. #10
    Join Date
    Aug 2006
    Location
    Elmhurst, IL,
    Posts
    327
    Default Ray. To go thru all that work
    Ray. To go thru all that work and be that close to the cam? Horsepower and boating adds up to big bucks. Do your homework. Find out from others what hp gains can be had and what speed was gained.
Similar Threads
  1. Going to a 4 barrel
    By mysearaysignature_200 in forum Mercruiser Sterndrive Archive
    Last Post: 09-30-2008, 07:39 AM
  2. 305 2 barrel
    By homerl in forum Mercruiser Sterndrive Archive
    Last Post: 08-23-2008, 11:56 PM
  3. My turn in the barrel
    By fastjeff in forum Chrysler Inboard and Sterndrive Archive
    Last Post: 06-20-2007, 08:42 AM
  4. Upgrade a 38 to a four barrel carb
    By chasboater in forum OMC Sterndrive and Inboard Archive
    Last Post: 10-02-2006, 12:58 PM
  5. Holley 2 barrel on 30L
    By russ0943 in forum Mercruiser Sterndrive Archive
    Last Post: 05-18-2006, 11:27 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
