"New to me, bought as-is with
"New to me, bought as-is with a bad starboard eng. I have aquired a 1978 Silverton w/twin 360 Chryslers. FYI port eng. runs fine. Starboard eng. had plug wires gone and no starter. Not sure of rotation or type of trany I have. Some possible clues: Cast on the eng block as near as I can read are as follows Model M360 B or 8 WR10-954 Ser.# E-508 634 Part# 10-20-78. On the intake manifold cast #s 05110 & 2848704, seem to be the same on the port manifold. Trany had "20" cast in case. Brass tag,painted red rivited to trany reads VELVET DRIVE Model 10-17-001, Ratio 1:1, Serial #10255 Borg Warner,Munice Ind. I did buy another eng on Ebay and was told it was a repl. eng and trany. Now that I just got it I'm not sure? Clues on repl eng. I was told it's out of a 1976 Luhrs with 250 hrs. Not so sure it's direct replacement drop in or even if I can even use it. Intake maniflod does have casting firing order of 18436572, and cast clockwise arrows of dist rotation. The trany reads Velvet Drive Model ASI-71C, Ratio 1:1, ser.# 91622 Borg Warner. Casting on block read ,4179930-360, one other thing the exhaust manifolds on repl.eng are pointing to the rear of the eng. opposite of my exsisting eng's since they face the stern. A lot of info any help would be appreciated.Thanks, Steve"
