"I have a 32 marinette. I am
"I have a 32 marinette. I am having trouble getting the 318 in time. the engine is reverse rotation, distributor turns CCW. I have the firing order set to 12756348. I assume that #1 is still in the left bank as with normal rotation? I have no timing marks on the ballancer and no markings in the distributor either, so my only way of determing tdc on #1 is the finger over the hole method. With all that said I still can not get this thing to start. it puffs and spit back through the carb. To me it acts like it is 180 out but if everything I mentioned is correct it can't be. I need some serious timing help, first time working with reverse rotation. Rebuilt enging with good compression, I got a deal on the boat becuase the guy got burnt out on the restore when he chipped about 5 teeth off the ring gear after installing the starter(rebuilt for normal roation)the correct starter and new gear are on now, but he did hear and see the engine run on the stand before the install."
