Power trim problem
duddy
"Help folks,
I have a 1988
"Help folks,
I have a 1988 Edvinrude 88 HP outboard.
Model E88MSLCER
My outboard motor will not trim up while underway. If I trim it up while stopped it will trim down when I take Off.
It will trim up and down when not underway or while on the trailer.
There is no sign of Hyd leaks.
Is there a check valve that holds the motor in the selected tilt? What could cause the hyd cyl to bleed down under pressure.
Thanks for any help."
"this will need to be taken to
"this will need to be taken to the dealer,to have the valves checked w a special tester...this is prob,the trim up,..relief valve,but sev will need to be checked.. jwb"
